1 - 16 of 16 Posts
Hey everyone,
I can get a greddy manifold with downpipe and turbo hotside(i was told the hotside was from a 15g greddy turbo(i know that in the manual it says greddy uses 19t). Anyhow, i was wondering if anyone might know if this turbo would be usable with the greddy hotside so that i can use the downpipe? Only reason im asking is because my friend has had it for a long time and is basically giving it to me. Any advise greatly appreciated. Also, i dont plan on buying this cheap of a turbo i just couldnt find any other t25 flanged turbo at the moment. I dont know why the link wont take you directly to the turbo but it's the one labelled nissan 180sx, 240sx 300zx etc.
http://www.speedyracer.com/turbocharger/T25-Flange-Turbocharger/TD04-H-T25T28-Turbo-86-AR-OIL-cool-240sx-S13-S14-KA24(270hp)
when you say hotside, do you mean the Elbow or the turbine housing itself?
that turbo will work with the greddy manifold. Greddy used 15Gs for the 92-95 kit and the 19T for the 96-00 kits.
The manifold will work for a nissan t25 turbo. The downpipe will not work.
They use different downpipe flanges.
Also there might be a few problems routing the turbo to ic.
Check my first build in my sign. I used a s20 turbo and a t25 manifold.
The turbine housing.
thanks, ill check it out.
no, you can't use a mitsubishi (aka greddy) turbine housing on a garrett CHRA.
ok, any ideas on what turbo could be used? It seems the only place i can find a "15g" is straight from greddy
a full nissan t25 will work but you'd have to fab up a downpipe.
i figured, looks like that idea is probably out the window then. the only reason i was interested in it is because i thought a different mitsu turbo could be used and i could keep the downpipe
if you want to keep the greddy elbow/downpipe setup, you're stuck with the TD04H turbine side.
if you find a 19T turbo, the compressor is a LOT better than the 15G
oh ok so any TD04H would work then? thats good news. ill look for a 19T.
You're really making it hard on yourself trying to use that downpipe elbow. All the "chinachargers", new t25 turbos under $500, will use a T3 CHRA so there isn't a snowball's chance in hell the turbine housing will fit. The downpipe elbow also uses 4 bolts instead of the typical t25 5 bolts, so you're limited to a turbo with TD04H exhaust wheel as stated above if you stick with the Greddy elbow.
The 19T won't benefit you very much, since the turbine housing & elbow combined are very restrictive. Some company makes a tubular elbow that still clears A/C. However if you don't have A/C, it shouldn't take much to get a china T25, a 5-bolt flange, and a 2.5" elbow welded up at a local shop. Speaking of chinachargers, the model you were looking at is tiny as hell! This is the best deal I've found for about the largest T28: GT2871 GT25 GT28 T25 T28 GT2860 Turbo turbocharger Water Oil Cooled 64 A R | eBay
the housing itself isn't bad, it's actually the highest AR you can get on a TD04H, and bigger than the biggest saab/volvo housings too (8.5 cm2 vs 7cm2 for the S60R).
the elbow is total garbage though - got a link to that tubular AC clearing one?
Thanks for the advice, i may just decide against trying to use a greddy setup then. I was looking for a small turbo though because i dont want to build the motor right now(got another project going on with my FR-S) and i want full boost by about 2800-3000 RPMS so i have a larger powerband. I was planning to shoot for a about 200whp with that turbo, do you think that it's too small for that?
Discussion Starter #16
even the 15G will get you to 250-260whp comfortably.
it's perfect for a stock block
nice, thats good to know. ill let you guys know what i end up going with.
1 - 16 of 16 Posts
