1 - 3 of 3 Posts
cool title
just got my partial greddy kit on and having a little issue with the wastegate. i hit a consistant 10-11psi without using a boost controller. from what i've been told the stock wastegate should open at 5.5psi and usually you'll see about 7psi if you run the wastegate line to a vacuum source on the intake manifold.
any idea why i'm seeing such high pressures? it wouldn't be that big of a deal, but im running this on a b7 and don't particularly wanna blow it up.
R2.....Zap Balls
94 Ex coupe
depends on how the rod is set on the wastegate. Try this, adj the rod so it's shorter. Make it where you have to pull it just a hair to get the rod on the wastegate, that should put you to right around 7psi.
1 - 3 of 3 Posts
