1 - 13 of 13 Posts
Well the kit is in and everything is running fine just one problem well my downpipe is toodamn small and i want to upgrade. WEll i was wondering what kind of flange is used on the manifold and on the exit of the 15g greddy turbo
R2.....Zap Balls
CR-Vtakin
vtecduck said:
beat me to it. i highly suggest that you upgrade to this. the small downpipe that comes with the kit is good for quite a lot of horsepower though. i made 176hp and 181ft lbs with the stock greddy downpipe, my friend made 250hp and 251 ft lbs with his stock greddy downpipe. just throwing that out for you.
R2.....Zap Balls
mainly i was wondering what the flange type is that that cast piece that connects to the downpipe is cause i want to fabe up a downpipe direct off of that
R2.....Zap Balls
ask kteller, they could prob tell you what it is. I have a custom fabbed 3" on mine. Looks almost identical to the kteller piece, just 3" instead of 2.5"
the only thing is i want to eliminate the downpipe and that other cast piece that bolts onto the turbo...ill email greddy. just want to have 2.5 inch allthe way from the turbo outlet...( 4 bolt flange) to the exhaust tip.
R2.....Zap Balls
ah the turn down that bolts to the turbo, not sure on that one, they do it like that so it's a/c compatible
well i called greddy and they said no major companies make a flange......ill give a shiney nickel to the first one who can find me one lol seriously oh yeah also im not concearned about ac......its dosent exist in my car
1 - 13 of 13 Posts
