1 - 12 of 12 Posts
just wondering if the grand national turbos are any good for a built d16z6?
thanks
See above...
Probably something similar to the T-bird turbos. Maybe a T3 .60/.63 60 trim or the smaller .60/.48 60 trim...
2011 VW Jetta Tdi
The A/R Hot side is .63 and Cold A/R is .60. The trim is .48. Model number is Garrett TB0348. Hope that helps a little.
See above...
^Ah, a 48 trim...then are the T-bird's T3 a 60 trim? or is that so bs I've been told? Just seeing if you know... Thx
2011 VW Jetta Tdi
Im not sure what the tbird turbo is for trim size. I know that the IHI unit on some of the tbirds is good for 250hp and the t3 unit from others is good for about the same. You can use the tbird ihi compressor housing and compressor wheel to make a hybrid with a probe ihi rbh5 that will give you good flow characteristics with minimal lag on a smaller displacement motor at lower boost levels than 15psi.
2011 VW Jetta Tdi
It really depends on what year GN youre talking about. If its the 87 then it probably did have a super 60 but good luck finding a turbo off of one from that year. From 84-86 i know they used the turbo i mentioned above.
1 - 12 of 12 Posts
