1 - 7 of 7 Posts
02 honda civic ex
ok.. i got a 91 crx and i bought in with a bad fuel pump, i replaced the fuel pump and noticed that the tank was rusted pretty bad. i tried to clean in, came pretty clean. i put the new fuel pump in and bolted back up. i blow out the lines and changed the filter. so i put 4 gallons of gas and i can hear the pump whinning. but no start. i go back and get 2 more gallons of gas and it starts. but now at half fuel tank it dies, but anything above half your good. so i replased the tank with a new one, and repeated the process.
and now it is still doing it.... please help me...
thanks all info is good info
racist-bigot-sexist-homophob
Sounds like you are fucking up the install dude.
No offense.
98 Civic EX
He is referring to the fuel pump installation...the fuel pump doesn't work with over half and not work with less...sounds like the fuel pump pick is sitting to high due to improper installation...this is what he means
Yup.
Well?
take bean-o, your gas will go away.
1 - 7 of 7 Posts
