The wife and I pulled the trigger and got a brand new, 6 speed manual 2017 Civic Sport hatchback! Has 112 miles on it =)
The clutch is weird, it has literally zero resistance
L15B7 Engine Type: (DOHC) In-Line 4-Cylinder with Single Scroll MHI TD03 Turbo and Internal Wastegate Boost Pressure: 16.5 psi Displacement: 1,496 cc (91.3 cu in) Direct Injection Bore and Stroke: 73.0 mm x 89.4 mm Compression: 10.6:1 Power: 174 HP @ 6000 rpm Torque: 162 lb·ft @ 1700-5500 rpm Redline: 7000 rpm
I picked up a 1990 Civic DX Hatchback a few weeks back. It came with a JDM D15B and a 88-91 SI Transmission. I might keep the D15B I might not, I have a few extra D16Z6s. The SI transmission will love the ZC I have sitting in my garage, along with the 3.083 1st gear that is currently sitting on...
Picked up a 91 ef hatch in trade, came with a high milage d15b2 that burnt oil and ran rough.
Upon inspection, found that cylinder 3 had low compression. Alternator was dead, distributer nearly fried, tps sensor and map sensors both bad, fouled plugs and incorrect plug wires.
Came with alot of...
It's been a while since I have been active on DSO, mainly because I moved to Hawaii as the worship pastor of a church. However that doesn't mean that I have given up on the world of Honda's, building heads, etc. I mean, I built a 91 wagon and shipped it to O'ahu so that I could enjoy my ride...
What the f20c
My new project!
2003 silverstone metallic s2k
Current mods
Legit Work vs-xx 18x8.5 225/40 front 18x9.5 245/40 rear
Neuspeed springs
Stock airbox mod
Greddy catback and test pipe
Hey guys, I'm new here. Posted this on honda civic forum and no one seems interested so I hope I can get some appreciation here. Bought my 99 civic for 900$. Got the Z6 head and crankshaft as well as vitara rods and YCP pistons all for 250$. I pulled the engine and just stripped down the short...
