1 - 7 of 7 Posts
EG6
is this a good restrictor or just get a fitting? what is a good place to get oil feed and return flanges? or kits for a t3 .42/.48... thanks dose the Stealthmode OIL Line Kits come with a restrictor?
try to get a thread in type restrictor. the one pictured will work just fine though with a good gasket.
im not sure if stealthmodes kits have oil restrictors included.
ps. dont go with an adjustable restrictor.
^^curious why your against an adjustable restrictor.
-Luke
racist-bigot-sexist-homophob
IMO a thread in type would be better. You can an adjustable one from stealthmode but I got my thread-in type at mcmaster-carr.
-Luke
i would have to guess that most people wont install a gauge after the restrictor. they wont know if they are restricting enough or they close the valve to much causing turbo failure. an adjustable restrictor is great, if you have a gauge after it so you can monitor the pressure going into the turbo.
Ajxr is the website for them mcmaster-carr.com their website ??
Reactions: YoungGuna267
I think so but you can GOOGLE it just to be sure.
1 - 7 of 7 Posts
