1 - 4 of 4 Posts
the main question I have is do you notch the block before or after boring. I'm guessing before, but then what if you aren't going to have it bored? also, curious about the specific tools you've used to notch it. I seen a link to HF carbide bits, but in that main article that everybody links to it says use a finer bit or something for the finish. I guess I'm just looking for a more detail info on this. someone should really do a diy on this with exact tools and everything.
then I guess you really don't have to worry to much about going over it with a finer sand paper or bit on the cylinder, just the girdle.
1 - 4 of 4 Posts
