1 - 7 of 7 Posts
8
sohc motors, lay it out for me :)
N/A, boost, wutever, give me a good setup :)
J
it all depends on how much $$$ you have and what class you are running in autox....post back with your class and budget and we can probably guide you into a baseline setup. also keep in mind suspension and personal driver skills improves times alot more than most engine mods unless you car is particularly underpowered for the course....
-Juan
Dont know whats best but I am gonna be running in SM2. 90 CRX Si, HF manifold, DSM T25 turbo (very fast spooling). gonna make good I hope
CR-Vtakin
your mom
if this is one of your first times out auto xing make sure to stay as stock as you can so you can get the feel for the car. then go from there and see what weaknesses your car might have and improve on that. What I would do if I were you is go get a rule book so you can determine what mods you can do for what classes.
2001 Z3 Coupe 3.0i
Just top off the oil and coolant... then go do some turning and burning!
CR-Vtakin
your mom
that is by far the best way to start
J
Okay since your in street mod 2 the ruls are VERY open. I would tell you if your new get what you can out of the engine but dont push it to much. I figure if you make 200hp (flywheel) your are doing great already ) concentrate on driving, and getting a feel for the car once you get consistent times on street tires (start out with those so you can learn the car better) then switch to the widest rim that you can fit under there with R compound. (remeber its all about the contact patch) I recommend the kumho's because they are cheap and decent as far as R goes (especially if your learning you dont want to flat spots some hoosiers and start crying...)
now if you dont have the $$ to do all this. I would 1. consider a different class (or if thats not an option) then 2. concentrate on driver improvment and better tires, suspension(in that order)
-Juan
1 - 7 of 7 Posts
