1 - 20 of 21 Posts
Hi, i am looking into a good SOHC project for my 92 hatch. As of right now i have a D15B (jdm) engine with a dsm turbo running 9psi. My questions are:
What is a good engine to boost, good tranny, and good turbo?
This is the first time on building an engine soooo completly nervous. If you could just give me some good product, tips and parts for this project.
Thanx,
turbovx92
95 honda del sol Si
tip: use search button.
don't be nervous. rebuilding isn't that bad. just take your time and do EVERYTHING right. there's nothing more heartbreaking than getting your motor all put together and installed only to find out you have to pull it all back apart for something stupid.
best of luck to you.
95 honda del sol Si
^^ thanks for reminding me..
set your hp goal and devote ALL your time/money/parts toward that goal and try to not change your mind or it will cost you MORE.
Thanks guys. My hp goal was set at 300 but from what i was reading D series are fragile at 220 hp so im still figuring the hp stage.
OMG TOTALLY COOL TITLE!!!!
88 y49 crx
you have alot to learn still. browse the FI section and showcase to see what some ppl are running and what setup they have and once you get a better idea of things you can make better educated choices on your hp goal and how to go about getting there
insert user title here
domestic.
honestly youre not going to get a quick easy answer. the best way to learn is to dig inn the material and read the info.
all of this wealth of knowledge here for a reason.
so to save you the hassle of looking for all the stickies, here you go.
please read
http://www.d-series.org/forums/forced-induction/77291-turbo-nitrous-faqs-info-look-here-first.html
http://www.d-series.org/forums/forced-induction/102717-read-if-your-thinking-going-turbo.html
http://www.d-series.org/forums/forced-induction/91529-junkyard-turbo-id-list.html
http://www.d-series.org/forums/forced-induction/112718-compressor-map-reading-dummies.html
94 Civic LX
the d series are only fragile in stock form. in built form they are monsters
95 honda del sol Si
are you planning on just dropping a turbo on your d15b or are you going to gut it and work on the internals too? cuz that makes a BIG difference in attainable power.
well i already have a stock d15b with a dsm turbo on it. and its only pushing 197hp on 9psi. my plan was to build a engine up and turbo it.
Wagovan
Z6 is basically the same motor, stock cam profiles differ. If the setup in your car is doing just fine then pick up another D15b or Z6 and build one for the amount of power you want it to make.
88 y49 crx
please read
thanks sean
/thread
dont take no short cuts..do every thing right and dont half ass it..if u want any thing out of it rebuild the bottom end..im working on my build and ill be buying most parts off of go-autoworks and fj..nxt purchase is the tuner stage turbo kit with the gerrett t3/t4 57 trim 6/3ar..the kit is capable of 250-450 as posted on site so thats fine with me..sorry if i didnt give you ny good answers but u catch the drift
1992 Civic Si
Building a D16 IS a shortcut. I have no problem with used or china parts, depending on what they are.
If you want all new parts, buy a new car.
1 - 20 of 21 Posts
