1 - 20 of 24 Posts
I am going to the dyno on Saturday, they have a dynopack or something where they attach to the hubs.
Apart from oil and water is there anything else they need to know like gear ratios?
Do they pull in 3rd gear?
Any tips welcome cos I am there to tune cam timing to see which one produces the most power. Now it is set at 0 degrees though with 1mm shaved off the head..pulls great at the moment.
yeah I'll do mine in 4th, its more load on the engine so I'll be getting longer pulls = more a/f resolution
basically more dyno time for the same ammt of money
With a loading dyno you can change the ramp rate to accomplish the same thing...i would imagine you can do it on a dynapak (sp), i know you can on a dyno dynamics
10 second daily driver :)
On a dyno pack its not so important as to if you use 3rd or 4th unless for the above stated reasons, however on a roller type dyno some high power cars will smoke the tires in 3rd so they have to use 4th.
RESULTS:
+1 degrees : 120.7PS @ wheels
-1 degree : 122.6PS @ wheels
Temp ~ 27 degree humidity 65%
Time between runs 10 minutes.
D16ZC sohc
Stock bottom
Dual carbs (with oem filter)
272 deltacam
4-2-1 manifold
5-Zigen exhaust
Light flywheel
DIY port and match job
They say it is really not bad for a non vtec..first they have seen
The valves were really noisy at the end, they took it to 8000rpm!!!
Any comments or improvements??Thanks
I will see if I can have video up..quite long.
1 - 20 of 24 Posts
