1 - 3 of 3 Posts
K
a n00b question:
doing a y7/y8 mini-me swap.....also going OBD1 to bypass the y8's knock sensor and a few other things....
since the OBD1 civics had just one o2 sensor (i think....) instead of 2 like my '96 CX, will i be able to just go with one o2 sensor installed in an aftermarket header?!?
in other words, will there be any driveability/performance problems just running one o2 sensor with a OBD2 to OBD1 setup?
since the OBD1 ECU will just be looking for one o2 sensor, this shouldn't be a problem right?!
help?!
K
thanks again man....
once again you've hooked me up with info.....
this site is the shizz.
anyone else ever go from two o2 sensors to just one?
1 - 3 of 3 Posts
