1 - 10 of 10 Posts
Building a del Sol for a friend who is flying cross country to get it and driving it back home.
I'm not after horsepower.... 110-130 is plenty.
So flow and reliability are my only two concerns. So I am thinking getting a b7 block, z6 head with b7 cam and cam gear (don't want vtec cause it burns oil) vtec block off plate. And a y8 head. Also considering going with beefier rods. Car will only be allowed to rev to stock limit of 7200. Other than the rods and block off plate, I want to use as many OE or OEM parts as possible.
The motor will get a complete rebuild. If you have any recommendation on parts please let me know. Car will get a short ram and a full custom exhaust.
My questions are:
Does any other set up flow better?
Any issues with block off plates in terms of reliability?
Would I be better just leaving the vtec solenoid bolted on and unplugged?
Is it even worth a z6 head for the better flow if I'm running non vtec internals?
Being a vtec head but non vtec cam is it okay to rev it the extra 300 rpms even though its not a true vtec motor?
If I do go b7 block z6 head with b7 cam and cam gear will I have any timing issues?
Any good brand pistons (with stock compression ratios {9.1-9.6}) to run if I can't find any new oem?
Any recommendations for the head, valves, springs, retainers, anything? Open to ideas even though I do want mostly stock.
why make it that much harder?
d16a6 block and head.
y8 intake.
profit.
oh yeah
s
e
a
r
c
h
non VTEC 88-95 cam doesn't work in the VTEC head....
VTEC doesn't burn oil...
short ram intake loses power and tq, as tested in 1998 and 1999.
y8 intake.
yup.
If you don't want VTEC op, then don't bother with a VTEC head . . . this isn't a b-series where the VTEC heads are noticeably better. While I'd argue the z6 head is the best d-series head, it isn't worth much when your setup is basically a stock rebuild AND you don't want VTEC.
Secondly, why limit yourself on displacement? Get a complete a6 or y7 motor and run that with the y8 intake.
Discussion Starter · #7 ·
I did my research before posting
I want fuel economy too. I figured it was implied with flow, I want efficiency.
Whats the big difference between a a6 and a b7? aside from 100 cubic centimeters? Also I have to have at least a 93 block because its going to a damn emission/inspection state. So no I can't use a crx d16a6
Short ram is less power than a stock airbox?
Also I do like the b7's my first and only b7 got 375k being beaten to hell since i got it at 329k and still more reliable than my 2007 camry on its fourth motor. I scrapped the body cause of rust and kept the motor and trans. I seriously considered honing it and replacing internals.
Discussion Starter · #8 ·
Isn't there some major differences in the journals? like the number of holes for oil to flow through between the b7 and y7?
see, if you did search, you would have answered your own questions.....
2005 Legacy GT
B7/Z6 mini me - I/H/E - 38+ FWY mpg (in a sedan ... got 47 mpg one trip). Change to z6 transmission for extra fun - and approximately same mpg. VTEC doesn't burn oil unless something is broken, like valve stem seals, valve cover gasket, rings, etc. Even making almost 200 whp my engine never burned a drop after it was freshened up.
Keep
It
Simple
Stupid
1 - 10 of 10 Posts
