1 - 20 of 82 Posts
Acura TL-P
GO-AUTOWORKS Street Kit D Series Special!
This kit was put together to be one of the best complete "lower priced" kits on the market! Perfect for the stock motor or mild builds seeking anywhere from 150whp-350whp. This kit is using the same high quality brand name components as our other kits as well, NO KNOCKOFFS.
This has been something I've been looking at for a while, and will more than likely replace the Tuner 1 kit (which will make the "Tuner 2" just become the "Tuner kit" )
Without further delay, the GO-AUTOWORKS.COM D Series Street kit.
This kit will include:
GO-AUTOWORKS cast T3 manifold
Garrett T3 60 .48 A/R turbocharger (upgrades available)
Tial silver 38mm wastegate
Tial silver 50mm blow off valve
38mm dumptube
2.5" Stainless downpipe with flex and O2
GO-AUTOWORKs Pro oil feed and return kit
GO-AUTOWORKS Race charge pipe kit (2.5"/2.0" standard)
silicone coupler set
T bolt clamp set
GO-AUTOWORKS Intercooler
$1970 w/ $25 FLAT RATE SHIPPING in the continental US
92-00 Civic
D-Series.org Members
Get a FREE turbo Upgrade Options:
-Garret T3 60 .48 a/r
-Garret T3/T4 50 trim .63 or .48 a/r
-Garret T3/T4 57 trim .63 or .48 a/r
Upgrade to a 3" NON A/C downpipe for only $20 more
Upgrade to a 2nd O2 bung for only $5 more
Opt for a A/C compatible downpipe for only $75 more
Opt for a closed loop dumptube for only $75 More (non a/c)
Bullseye Power .70 a/r 50 and 57 trims available also :bigok:
Add a wastegate elbow (to clear 88-91 Civic/CRX hoods) for only $60 more
___________________________________________________________________________
Max713 w/ Street kit and Bullseye 50 trim upgrade
Acura TL-P
Thanks, once we get this batch of Greddy downpipes finished up (started on 4 yesturday), then the Street kits will be getting put together for stock.
Acura TL-P
my burfday is july 12, do i get a special july discount on something...lol. i want to see those dyno numbers for the elbow and dp. im debating to change my setup for something that can make alittle more.
The Greddy dynos should be tomorrow I think :TU:
This is a very reasonable price once again you out do yourself. These should sell pretty well. Are you using the same design mani as the ebay/ drag or....
Yes, same design. I've been debating the few days on sending the whole batch out to get Jet Hot coated inside and out, jsut waiting on a call back on the price.
Hi hater!
oh ok cool is it gonna be the 1650 degree stuff. If you do it would love to see some pics because mine looks so ugly with that rust color.
1 - 20 of 82 Posts
