1 - 6 of 6 Posts
98 civic
ok so i know with any H beams in our D's u need to notch the bottom of each cylinder.
but do u have to notch the girdle as well?
and would replacing the cam gear need to be done now or could this be a later on thing? (replacing to a adjustable cam gear?)
98 civic
i have heard that before as well but i wanna know for sure if the girdle needs to get notched and about the cam gear question
TT rods is the rods im useing
racist-bigot-sexist-homophob
Depends on the rod bolts as Hellhatch said. I did not have to notch mine (girdle).
R2.....Zap Balls
94 Ex coupe
x3, mine didn't have to be with my eagles. As for the other ?, you can replace the cam gear at a later time and be fine.
1 - 6 of 6 Posts
