1 - 6 of 6 Posts
9
I have a 94 DX stock:
1.) Am I obd-1 or Obd-2
2.) If I get a bare EX intake will all my sensors mount up to it, or do I need the ex sensors?
Thanks
Mat
1.obd1
2.if you mean a z6 manifold, there's only one possible difference. SOME b7 engines have the MAP sensor mounted on the firewall instead of the throttle body. I have your exact car (sedan though) and mine was mounted on the throttle body. Everything else is the same.
9
Do you have a pic of what the map sensor looks like?
no...
it's either a little black sensor on top of the throttle body with a harness plug attached or it's a black sensor on the firewall with a vacuum hose coming from the throttle body and a harness plug.
also, i think the throttle body on the b7 and z6 are the same size, so you can keep your old TB if there's nothing wrong with it. That way you don't have to worry about the map sensor.
9
Cool, I am bidding on one on ebay. We will see if I get it.
1 - 6 of 6 Posts
