Hi guys, just had my clutch replaced at a garage, but now in neutral the stick seems a few inches forward and if moving the gearstick left and right whilst in neutral there seems no 'cushion' when moving to the left when you would select 1st or 2nd gear. It drives ok but in 1st and 2nd gear you can feel the gearstick vibrating against something and it generally feels looser than britney spears' vagina :wacko: the righthand side of the shift feels fine though, any ideas? thanks
Wagovan
Take the boot off and look at an exploded diagram of all the shifters components. take yours apart and see if your missing anything.
See above...
Did the geniuses install the shifter linkage and stabilizer bar wrong? Can that even be possible? LOL
EK hatch
It acctually is, it's hard to do but it does sound like your linkage wasn't installed properly, if your under the car you should see two bars cross eachother about 6in. from your shift lever, this installed the right way doesn't look like it should go that way but it's the way it is. Can you get under your car and put up a pick of your linkage? Also, when you say garage, do you mean an actual garage or a shop,if a shop dont waste time take it back and hit them with a big WTF.Sheasekhatch
i had a look at the weekend and they HAD put the gear stick on back to front, i fixed that and its fine now but apparently the garage (think thats what you guys call a shop in US) never touched it, yup it must of jumped out its mount and turned itself around wow omg!! yup so thats another garage on the do not use list
1994 del Sol S
If they replaced your clutch, they had to take your shift linkages off one way or another. Wether they unbolted it from the exhaust tunnel, or from the tranny side, it has to come off to get the trans out of the way.
