1 - 3 of 3 Posts
EG8
I've read through most of bone's posts regarding transmission tech and am having issues finding good pictures of the gear/ sleeve deburring process. I've gotten a lot of differing opinions on how this should be done. Bone suggests a 120 grit flap disc multiple times and none of the pictures associated with this process exist any more. I've also been told to use a brass wire wheel on a bench grinder and a steel wire wheel. In a perfect world I'd send everything off for REM polishing, but this is a street car and a lower power d-series.
Anyone have some info/ pictures on this?
EG8
Thanks for the response bone!
When you de-burr are you hitting the leading/trailing edges of the gears as well as the face of the slider hub splines?
1 - 3 of 3 Posts
