1 - 4 of 4 Posts
Hi, I would like someone to explain me what are the differences between these transmissions (performance wise) from the numbers in the attachment.
All three are automatic transmissions, the first two came from SOHC engines found in 96-00 Civics, and the last one is from a B16a (SIR II).
I notice that the D16Y8 transmission seems better for top end, i might be wrong, though...
I would like someone to explain what does those number means, how to read them, etc...
Thanks in advance!
Sorry, I will reword my question, since it seems I had the wrong idea.:
Will the MPRA transmission rev higher?, will it drop less RPMs than the other two, because of the gear ratio?
Will it reach a higher top speed because of the final reduction?
Thanks again
1 - 4 of 4 Posts
