1 - 4 of 4 Posts
Has anyone hooked up an electric oil pressure and water temp gauge on DOHC ZC? If so where is a good spot to hook the oil press and Water temp?
i like to T off the stock oil pressure sender.
this is what i did...
for the water temp, you could just remove the stock sensor and install the new one (assuming the threads are the same)
1 - 4 of 4 Posts
