1 - 20 of 21 Posts
What gauges are really necessary? I am looking at some Autometer sport comps... I just wanted to get thoughts about this.... thanks!
68 Camaro
oil pressure, voltage, and coolant temp are the norm, if you really like gauges you can get an oil temp, vacuum, and fuel pressure
So far, i have a/f, volt, oil temp and boost.... i am thinking about getting rid of the voltage gauge and getting an oil pressure and egt? That egt gauge is spendy... is it even worth it? I am boosted and will be running 300whp VERY VERY soon...
honda/firebird form.
mechanical oil pressure guages are more accurate... lol they are both easy to hook up
well if you use the copper tubing, it wont burst like the cheap plastic ones... you cant even get pass tech with a plastic one if they see it
edit. mine has been working for over a year
so what do u recommend? mech or elec? for oil pressure
Where can you get copper tubing for these at? I have one, not installed yet but its got the plastic tubing, definately would rather have something a little more solid!
hmmmm yes.... this would be good to know if I go with mech.... bump
Tunerview 2, enough said. If I was to do it all over again I would go with the tunerview 2. But I got boost, oil pressure, and water temp gauges. Wideband is also on the list to get.
93 Legend L Coupe.
Oil pressure, temp, boost/vac. That's all the "necessary" ones as far as I'm concerned. Oh, and depending on how big your VTAK hit is, you might need a mega-monster uber-blingtastic tach w/atomic-powered shift light set to 10,000RPM.
autozone.. they have the copper tubing by the guage section
1 - 20 of 21 Posts
