Guys,
Where did you guys splice in for your power for your lights on your gauges?
The only other car I put them had the gauge pod replacing the clock, so it was uber easy. I don't have a clock, but can I splice into the clock wires on the Civic?
Thanks,
Doug
the under dash fusebox has a couple different 12v sources where you can use a spade connector I think there are 4 of them ones 12v constant ones only got 12v when the ignition is on and the othere is on the combo switch (lights)ill see if I can find u a pic
here just use a voltmeter to figure out which is which
well instead of splicing wires you can just plug into the fuse block I dont remember which one it is but when u turn on the lights so will your gauges its one of the 4 in my first reply thats circled in red
Nice, I'll probably do that. Thank you!
