1 - 6 of 6 Posts
ej2
I forgot the car was in gear, let my foot off of the clutch. Bloop..Car stalls.
I start the car back up, and now the gauge cluster is completely not working.
Turning signals, Clock, Temp, Gas, Rpm's, & Speedometer no longer work.
The only thing that works are the hazard lights... Any help guys?
ej2
So.. After a little research and inspection.
I found out the "BackUp-Light" fuse was blown in the fuse both underneath the steering column.
I replaced it with a new one, and boom. Blown again = |
My car...or my truck
Sounds like a short, check all the wiring under the hood, look for a wire that might have got pinched when you killed it....check the grounds too
When you stalled, with the jerk.. did you yank the reverse switch from the trans? They are 2 little 1 wire plugs under the distributor that may have popped out.
ej2
Thanks for the reply! Shit just happened to me to day again!:willy_nilly:
I'll check to see if those two little wire came unloose or something.
1 - 6 of 6 Posts
