1 - 16 of 16 Posts
Im new here, and rather new to honda motors in general. I plan on building a D motor either this year or next year. The motor will probably be going into a 1992-1995 civic (most likley a hatchback) Im assuming that the car will probably have a D16z6 in it (does that sound right?) I would like to know the best way to go about getting the most power out of it while not using a turbo or nitrous. The compression can't be too high because all the gas around here is 92 octane, 94 at a few gas stations.
If anyone knows a good way to go about this that would be great, also listing some parts would help so I could start building a list of what I need to get and how much I need to spend.
Well the compression can be increased but not past about 11:1 I think it is for 92 octane right?
91 CRX Si
Big tuna is running something like 13 or 14:1 and he can run 93 octane...
It just depends on your fuel management system I guess.
you could run 92 octane with 11;1:1..
My set up in my coupe:
a6 bottom end rebuilt
y8 head ported milled 40 thou. by JG
JG 85vt35 cam stock valves/retainers
Skunk2 adj camgear
FPR
apex 4-1 header
no cat
2.5 inch piping to magnaflow muffler
b4 the new bottom end(a6) I dynoed at 110 tq/127 hp
I havnt had it dynoed with the new bottom end, but im positive its near 140 hp.
I'm runnng 11.4:1 CR on 91 octane, and far from detonation. For a street car, I am probably fine to go up to 12:1 if I want. (not that there is much difference.)
My setup made 144 whp, 122 wtq with stock ports in the head, anmd stock valves. (I'll take care of that this summer)
http://www.d-series.org/forums/showthread.php?t=52008
140 hp sounds like it would be great for a little street car, if you don't mind me asking how much did that motor cost you toddnos?
i got the a6 block for 150
hot tank line bore hone deck 500
jg cam 185
mill/valve job 185
portjob 180
cam gear 85
header 200
fpr 120(aem)
This stuff was aquired over time
How do you like the cam your running? most of the companys that I know of only make cams for the b motors, do you know of any other good cams for this motor?
Discussion Starter #15 (Edited)
Ive been checking out the crowers and I think I will pick one of those up along with and aem cam gear. One other thing, I found out that the car Im gonna be getting is probably going to have a D15b7 or a D15b8, what I wanted to to know is what would I need for engine managment since the D15b7/D15b8 uses OBD-1 and the D16a6 uses OBD-0 and the y8 is OBD-2 and vtec, and what head gasket should I use.
1 - 16 of 16 Posts
