1 - 20 of 22 Posts
Hey guys I finished up my front suspension today and went to install my Full-Race traction bar but to my surprise i have quiet a large gap between the "frame" rails and the bar itself. The gap is probably a 1/4 inch or larger. Am I suppose to re-use the tow hooks or something? I've tried to call the Tech support at full race but I just keep getting a voice mailbox.
Here's a picture of said gap.
Yeah unfortunately I don't have the tow hooks anymore so I can't try. I was hoping to find out for sure before I make a trip to the junkyard.
1997 Civic DX Hatch
i did a little googling just at other images of people using the same bar and it doesnt look like they are using tow hooks.
so possible yours is the wrong size or for the wrong chassis?
if its less hassle to get the tow hooks then to return the bar id do that. you could also email the manufacturer and see if that it correct or not.
Love the Civic
Yeah I looked at pictures too and it didnt look like others were using the tow hooks. The paperwork that came with it said its for my car but who knows what was put into the box. I've already emailed them and called them twice today but no one is answering.
Do you have the large washers between the frame and the bar on the other side?
How To: Full race Traction Bars Install | ClubCivic.com - Your Online Civic Community
Was thinking wrong part for car too.
No I don't have any large washers like that dude is speaking of. My package came with a list of all the parts and bolts included and large washers are not on that list. It would really suck if the part is wrong or poorly made and has to go back since my car has been up on stands for about a month now.
Love the Civic
Or you could find grade 8 bolts nuts and washers. Find washers that will fill the gap on each side evenly. I dont know how this part works enough to know if you are weakening it by using washers between it and the rail.
I ended up getting a hold of them today on the phone. They said it should fit snug and asked me to send pics. They asked if it was hit before, which it was but not hard, and I tried it on both of my other civics and its short on those too.
Ouch, I also have the Full Race traction bar and it DOES NOT re-use the factory tow hooks. It should fit snug and re-use the oem bolts as well. The traction bar itself has provision as a tow hook as well as its incorporated with it already. So, you either have the wrong traction bar application, or your core support is bent :/
My core support is def not bent. I had no problem bolting up a new bumper support that bolts to the core support.
After talking with Full-race they told me to just force it on and allow the mounting tabs to bend a bit. I got it on, but certainly not happy with the fitment at all.
Meat Popsicle
91 CRX Si
That sounds shady as fuck man. Maybe someone with the same bar can measure theirs so you can compare?
My ESP bar, which also mounts in place of the factory tow hooks, was tight, actually had to work it into place with some force.
These things are made on jigs so theoretically, every one should be the same. Either they sold you the wrong bar, they made a mistake with this particular unit, or you have front end damage.
Tape-R taper/driver
EC3, ED8, ED9, EE5
Measure your bar tip to tip and Ill go measure mine.
you mention the car was in a wreck Id put my money on the frame rails being tweaked.
He also mentioned that he test fit it on other Civics he has access to that have not been in an accident and it fit the same way.
Ive been on the site for a long time looking but this will be my first post. Today when i went to install my full-race traction bar my del sol I had the same gap problems.
Here is the left and right side with bolts in and bar centered.
it wont let me post pics because im new on the site but the gap is the same size as the other pictures in this thread
My car has never been in a accident so that can be ruled out. I got in contact with full race and the customer service also told me that was normal and to just tighten it up. I fabricate stuff on my free time and bought this piece thinking it would be better than anything i could make. Common sense is telling me its not correctly made.
Anyone else with this bar having it fit snug? Am i completely wrong in my thinking and this is normal and the way it should be?
my bar from tab to tab measures 35 6/16 and the space in between the frame measures 35 15/16 give or take 1/16.
wont let you post pics because youre new? lol, find an outside hosting site
Yes when i try to post links or pics it will not let me. It says my post count must be greater. But anyway the gap is the same as the pictures from above so the question remains.
From searching it looks like others fit snug. Hopefully i can return it.
nice. way to go d-so. implementing things that were spoken about in the mod threads.
You guys nEED to put your foot down. You checked it on an accident free civic. there was still a gap.
The bar looses functionality to a point if the ears are bent outwards to make it work.
Clal them back and let them know ifs wrong and you want them to find a solution. you need to let them know you are not comfortable putting a CONSTANT stress on the entire front end by bending heavy gauge metal to work.
Eitehr make shims, or get a enw bar, or return for a refund and eat shipping cost.
Fullrace used to make amazing products. Hopefully they are not going the path of another warrior turned bitch-eemoto
1 - 20 of 22 Posts
