1 - 3 of 3 Posts
Hello I'm having issues with my car 92 civic most of the time I don't need to ask for advise but not sure what the problem is I rebuild the engine 8k miles ago its holding 210psi compression spark seems good it will randomly buck miss and stall its not the main relay/key switch engine runs very good when the problem isn't there it seems to be worse when its very cold outside also no check engine light. Thanks in advance.
plugs, cap, wires, dist, filter, timing, grounds.....
1 - 3 of 3 Posts
