I put in a sohc zc into my 98 civic lx and when I go and start
it. Fuel squirted out the fuel filter line I double checked it
and its tighten good. Anyone have an idea
on what it can be ?
If it's leaking from the banjo fitting make sure the washers are in it.
I took it off and it does have the ring . Its leaking by where the
bolt goes in. I made sure it was tighten twice.
ej1
Did you cross the banjo bolt on accident? **OK no**
If the bolt is threaded in properly, are you sure the crush washers are at the top and bottom of the banjo fitting and did you tighten the bolt enough to crush the washers into making a good seal? **OK yes** I'm stumped without seeing it. New washers right?
Im going to autoparts right now to buy a new
one. Ill post the results later
