1 - 18 of 18 Posts
i have a Z6 stock internals .5 over bore. dsm turbo (custom job) RX-7 injectors 460cc with resistor box. an air to air cooler for now 7 psi. waiting on the 255 fuel pump an ecm (chipped). the ? is should i just use the stock regulator or do i need an adjustable one...... some say yes others say no.... thanks and if so want psi should i start at. tommy
R2.....Zap Balls
you will be fine with the stock fpr
i save your ass when you wreck
i would get one. it never hurts to have more fuel.. id go up a couple psi. i kno when i ran nitrous i think i had mine set 2-3 psi above stock
they are not required to boost the engine or to have on a boosted engine.... but if you want one, you can install one. i have one currently on my boosted y7. but....
he will have a chipped ecu for adding fuel, i say he is fine with his stock fpr with his setup unless he really wants to push the 460s to their limit
i never said he wasnt fine.. i kno u dont NEEED one but id just get one for the fuck of it. its only 50 bucks
thanks guys if i really dont need one then thats 50 bucks i can put on a boost controller. would 10psi of boost be pushing it tho.
R2.....Zap Balls
you should be ok, there's people pushing 12-14 psi on a stock block. Just make sure you get a good tune.
yea but upping the pressure would up the hp limits of the 460s
passing the flow ratings of the injector right? well as cool as that sounds.... having a injector fail due to too much pressure is never a good thing, just like running too high on a duty cycle.
basically, is he/she gets to the point where they need to pass the rating of the injector, its time for bigger injectors.
R2.....Zap Balls
There's a few of us in nc, sc, and ga. I'm in greenville, sc. Not sure how far that is from you, I'm about 145 from Norcross
Discussion Starter #16 (Edited)
good deal. yeah Norcross it's about 3.5 to 4 hours north from us. we are n the DEEP south Ga. by the way thanks guys on FPR ? i had started GREAT INFO. THANKS tommy
agreed...i guess i just felt like mentioning it lol
1 - 18 of 18 Posts
