1 - 19 of 19 Posts
Ok, I have just installed a turbo on my 1993 Civic Hatch DX d15B7, now its time to take care of the fuel. I have got a dsm 450cc injectors and a walbro 255 fuel pump. Is the stock FPR ok with the 255? I have an aftermarket FPR but should i even worry about installing it? If I should, can I just run it after the stock one in the return line and just take the vaccum line off the stock one and put on the after market? If I do need the aftermarket one, what is the best way to bypass the stock one, with it still being attached to the fuel rail? I would really like to just splice into the return line after the stock FPR and hook up the new one. But i need to know what i need to do to the stock one in order to do that. (like leave the vaccum line on/off, jam the valve open?) but of course that is only if i do need to even run an aftermarket one with the 255. Some one please help!
im running a stock fpr walbro 255 and 750cc injectors and i have has zero issues
crx
I have a walbro 255 and have been running it with stock FPR for about 5 years, works fine. only time I hear of anyone realy needing an AFPR is when there injectors are maxing out or doing a custom fuel rail setup when converting a returnless fuel system..
Stock Interga FPR has a bigger bleed hole and will stay in control of the extra flow.
Stock Civic FPR cannot handle the extra flow at idle, you will have 55-60 psi at idle.
Meat Popsicle
91 CRX Si
I know from experience that the following OEM FPRs will work correctly with that setup:
D16A1
D16A6
D16Z6
D16Y8
Check the part number of your FPR in the parts catalogue and see if its the same as the Z6 part no
crx
I got mine off a Z6 the same day I picked a Z6 vtec solenoid at the salvage yard. my car has wround 30psi at idle and 42psi under throttle.
my car came with a aem afpr and I sold it for $50 cause I had no use for it once I picked up a stock Z6 fpr.
Ok I guess I'm not going to worry about it then. When I ordered my chipped computer, I had them delete the o2 sensor. Will this cause the car to load up on fuel at idol?
So you know the junkyard one was stock and unmodified?
95 civic coupe
Also running stock fps on a walbro 255 pump on my d16-t no issue
1 - 19 of 19 Posts
