hey all,
wandering if anyone can advise if it looks like i've got the FPR connected correctly?
im not getting any fuel through the injectors and doing the elimination process...
little hose is vacuum
horizontal hose is FUEL IN
bottom hose is FUEL RETURN
thanks!!!
That is correct (if that FPR is set up the same as an NRG off rail FPR). If your not getting fuel to the injectors, disconnect the fuel line between the filter and the rail. Prime it, if you are getting no fuel there then your pump is not working.
I had a problem yesterday where the o-ring on the FPR fitting was leaking at the rail (same setup as OEM but off rail FPR). so there was fuel in the rail...I replaced that and now i know that the plugs are dry when cranking... so there is no fuel into the cylinders... thought perhaps this was an issue with FPR...
STOP!
WTF is that bullshit setup?
Two fuel line close to a belt, MAJOR DON'T FOCKING DO THAT!
Not the place to be cheap, unless you like roasting smores over your Honda.
Get a rail mounted FPR like Aeromotive, sure mine cost me $175, but no worry about a charred shell!
relax... there is at least 10cm of clearance between the belt and the fuel lines which are strapped up and won't fall down... you just can't see it in that pic. I wouldn't be crazy enough to let the lines hang around and be within reach of moving parts... hehe
Gues you've never seen a belt flung off on a missed shift.
I've already seen one car lost like this, so roll your dice.
