1 - 3 of 3 Posts
00 civic dx cdm
bad gas mileage (really bad) + gas smell. checked underneath car and seems wet (check pic)
i used regane gumout maybe a week prior to starting having bad gas mileage
fuel filter is new
which line u think is leaking? feed or return?
ej8
drop the tank and your lean alot more.
The return happens to be rubber while the feed is mostly metal lines.
So i would say its the return that is leaking.
But drop the tank and clean everything up really good. Check for broken or cut line of course. But then throw some baby powder on it and put it back up. once everything is together start it can check for leaks.
The baby powder will make it alot easier to see the starting point of the leak.
00 civic dx cdm
thanks for the reply, right now i dont really have means to take off the tank... how i wish i had my personal work space... anyways the baby powder idea is good i will give it a shot
thanks for your help
1 - 3 of 3 Posts
