Lately the car has been putting out a lot of fuel fumes while idle. My cabin air intake seems to suck it right out of the bay and pump it into my face. My nose leads me to either the fuel filter (which looks perfectly fine) or the EVAP canister (which has everything attached except the vacuum).
My build is a 95 Civic Hatch CX chassis with a D16Y8 edelbrock turbo kit (with the exception of a Disco Potato- GT28RS), vitara pistons, stock cam, supertech springs, port and polish, blah blah. Basically the engine should be comfortable making 300hp. Right now I'm sitting at ~175hp because my exhaust is choking the hell out of the engine, but that's another topic.
I've been told that it doesn't matter whether the EVAP canister is attached or not. Lately I'm beginning to think there might be a pressure buildup in the canister, but I don't understand the mechanics of it, and how lack of vacuum would affect it. I'm all for getting better mileage, and if that will help I'll put it back together with a new solenoid (old one broke during build).
Question one: Can the EVAP canister have a pressure buildup without vacuum?
The second part is a bit simpler. I have a stock FPR on the fuel rail and the tuner that worked on my car said I had to rev the engine every time I started it, otherwise it would stall. He couldn't figure out why it stalled. This sounds to me like the compression chamber is getting flooded by the Walbro 300lph pump when it primes. I know there was a mod (TheOldOne) that intended to fix that, but in the rush of moving across states I never was able to get it done.
Question two: Could the pump be flooding the compression chamber, causing the engine to stall while starting? Is there another possibility?
