1 - 20 of 462 Posts
This is a brand new tucked engine harness. It runs from the motor straight to the ecu and uses ALL NEW mil spec wire, pins, seals (where seals can be used ) ecu plugs and nylon sleeving with adhesive Lined Heat Shrink Tubing.
Will work in all 92-95 civic and 94-95 integras, with d or b Manual Trans. swaps. Harness is wired for vtec, set up for an obd1 alt, dizzy and injectors. (if you need obd2 alt, dizzy and or injector plugs i can pin them on the harness as long as you have the plugs).
Price is $450 plus your old harness...I'm also including new 8 ga. power wire from the alt to under hood fuse box.
THIS IS NOT A HACKED UP HARNESS, it is a new harness.... everything used is brand new except for the engine sensor connectors and a few seals...this harness bypasses the pass side shock tower plugs meaning they will not be used,,just the driver side shock tower plug will be used.
i can make a harness with a mil spec quick disconnect if you want that type of harness....see last pic...harness can be covered in nylon sleeving or raychem heat shrink....pm me for price..
4 wire o2 extension harness $32.00 shipped
vtec subharness obd-1 or obd-2 $32.00 shipped
distributor adapter harness both version $40.00 shipped
plug and play obd-2 resistor box harness(harness only) $32.00 shipped
there are more pics are threw out this thread....
[/URL] Uploaded with ImageShack.us[/IMG]
Formerly 95RedVXCivic
95 VX, 88 S/C MR2
looks good! free bump!
Discussion Starter · #7 ·
thanks man....
can you make one with the round 20/40 pin connectors, you connect at the firewall, so you only have to unplug one connection to pull the motor?
pmed....
you want the price to go thru the roof?? :pinch:
its not that much more....
If I knew where to get those freaking round connectors, Id make one myself! Wouldnt be hard at all! Last guy I asked wouldnt cough up where he got his though....
theres a lot of work and time that goes into make theses harness plus the tools are expensive for a one time use...
^ google. I found where to get them.
Btw GLWS harness looks good.
there all different and some are even ugly....thanks...
Discussion Starter · #8 ·
new pic added.....
Discussion Starter · #9 ·
up for a custom harness......
Discussion Starter · #12 · (Edited)
so did i miss the price or is it not there?
its there,just above the bold letters....you missed it.....its $440 shipped (paypal fees are included in the price too) and your old harness,price does not cover the shipping of your harness to me.....if you want to send your drivers side harness i will deloom and separate it for you for free....
Discussion Starter · #14 ·
Discussion Starter · #16 ·
Discussion Starter · #18 ·
Discussion Starter · #19 ·
i added new pics of the harness installed on the car.......
1 - 20 of 462 Posts
