1 - 2 of 2 Posts
1991 Honda CRX
This was on a turbo D16Z6 I had, and two -10 AN male fittings were welded to this valve cover for breather ports. The OEM baffle was removed and had some added holes drilled out to aid with breathing while maintaining the high quality OEM baffling. The OEM baffle was tack welded back in place (where the factory rivets would be).
This valve cover was used for a while with the modifications listed, but it just had a fresh powdercoat finish applied. I no longer have the D16Z6 so I no longer need this. If you don't have a use for the AN fittings at the moment you can buy caps for it for fairly cheap. $110 shipped to the lower 48 USA. If you live else where just PM your shipping information and I will get a price for you.
1 - 2 of 2 Posts
