I will look at the part number and see if it is specific. I know it does not work on my 89 sedan. . but then again, that is way different than a CRX. .I would have had to drill holes in a different place to make them work right. So, since i did not want to mess with perfectly brand new mud flaps, i thought i'd sell them. . .and get the ones for the sedan.for what year crx? i was under the impression that some year's had different mounting points then the other? 88-89 and 90-91? if not then i read some bad info. bump for you though.
I got back late last night. .i did not check this out. . i will look into it today. Sorry!for what year crx? i was under the impression that some year's had different mounting points then the other? 88-89 and 90-91? if not then i read some bad info. bump for you though.
It just states it is for the CRX. That is all it says. It may work.for what year crx? i was under the impression that some year's had different mounting points then the other? 88-89 and 90-91? if not then i read some bad info. bump for you though.
