I'm on the same tire/wheel size and ride height, only with HardRace stuff all around.For a pure street car with little to slightly less than moderate power upgrades; I will agree with the HardRace assessment. However if the power plant is a bit spicy you might want to look at the spherical rear lower front, with energy suspension poly on all 3 other front locations, a modified rta bushing from energy suspension, with spherical adjustable upper rears and spherical toe adjusters, with energy suspension poly throughout the rest of the rear. If the power plant is outrageous look at a spherical rta rather than a poly with tapered holes drilled in it. This advice is all based upon recent(12 months) experience with 92-00 chassis, with ride quality, linear and lateral traction in mind, different combinations of aforementioned components can yield an entirely different feel and soul to the car, aiming it at different things.
I myself like an all-rounder, currently running 195/50r15 with a progressive -1.25/-1.50" drop spring, ES poly bushings all around,(rta bushing modified with 3 tapered holes) kyb gas-a-just struts, and the street performance is unparalleled, track cars ive built that beat my car by 2.9+ sec per lap at willow springs can't keep up from light to light, let alone sign to sign, which is really where my DD loves to dominate.
That's what I get for raw-dogging them.If they aren't kept properly lubed the life span is severely reduced, my last set lasted not quite 10 years of daily driving and being beat upon regularly before slop showed up and caused wheel hop on moderate launches.
