1 - 2 of 2 Posts
Long story short, i had to change my injectors back to stock on my civ. just wondering what pressure should i run for the FMU. right now its around 38psi idle. & 59psi. lean ? rich enough ? thx.
You should put your FMU back to its original settings, take it off, get your Z6 ECU chipped and tuned the right way with your 240cc injectors that won't last for much higher than 180-200 hp.
1 - 2 of 2 Posts
