1 - 17 of 17 Posts
1999 civic Hatchback
Well guys we will be giving some neat deals! Some are permanent and some are till the end of the month of March.
Now all of our ACL Bearing Kits will have FREE Shipping to the USA. That includes ACL RACE Kits as well as ACL Duraglide Kits. The Kits include Rod Bearings, Main Bearings, Thrust Washers.
ACL RACE Bearings kit for Honda only $99 shipped to the USA
We have also available from ACL RACE:
Hoda/Acura K20 Bearings
Nissan SR20DET Bearings
Nissan G35/350Z Bearings
Mitsubishi 4G63 EVO and Eclipse bearings (Please specify year)
Subaru WRX/STI (Please specify year and engine)
Toyota 4AGE bearings
Items with Free shipping to the USA till the end of March 2009:
YCP Vitara Pistons and rings--> any bore Size
Full Engine Gasket Kits--> D series, B series
Nippon P29 Pistons and rings
YCP P29 (75mm, 75.5mm) Pistons and rings (76mm on backorder)
YCP PCT Type R Pistons (81mm, 81.5mm, 82mm) and rings
YCP B20 Race Pistons (84mm, 85mm) and rings.
Items with Permanent Free Shipping to the USA:
AEM Wideband 6-1
ACT CLutches
Bullseyepower Turbos
Competition Clutches
Clutch Masters
CP pistons
Edelbrock Intake Manifolds
SKUNK2 Intake Manifolds
Blox Intake Manifolds
COMETIC Gaskets (Coming Soon)
Other Specials:(please contact us before buying)
Bisimoto engineering.
5% off when you order a Cam/Springs & retainers/Cam Gear Combo.
$10 dollars off selected individual Bisimoto Products: Camshaft, Cam Gear, Springs & Retainers(together)
Free Shipping to the USA on Bisimoto Intake Heat shields
FJ R SPEC Connecting Rods.
FREE Shipping to the USA on any PRE Order of D16 I Beam Custom Length OR any Vitara Piston & Custom I beam Combo Order. Only till the end of March
Here is how it works. On the checkout process write in the comments FREE SHIPPING March Offer.
We will refund back any shipping charges at the time of sending the item. **Please note that at this moment the Custom I beams and std. length H beams are on Backorder. Estimated time of arrival is 3 weeks.
KMS Engineering Products.
KMS Blockguards in special (All honda Engines)
D16A6 Springs & Retainers in special
D16Z6 Springs & Retainers in special
D16Y8 Springs & Retainers in special
B series Race Springs & Retainers in special
Stay tuned for more stuff coming soon...
Thanks.
Is there a chance for YCP PM3 76mm again? I know I am repeating myself, but after having my cylinders bored I am kinda limited on options. Thanks
Let me find out tomorrow if they are available.
Thanks
im looking at the d16z6 gasket kit, what all gaskets are included with this kit?
All the gaskets and seals...
From the top of my head:
Head Gasket (Metal 3 layer)
Valve Cover Gasket
Oil Pan Gasket
Intake manifold gasket
Exhaust Manifold Gasket
Spark plug Seals/grommets (4)
Camshaft seal
Lower front and rear seals
Valve stem seals
Throttle body gasket
TPS gasket
Water pump seal
... and some other that i know im forgetting... It a complete kit for the engine
Hey FJT does free shipping include HAWAII???
Thanks
I can work that out on some items... mainly the ones that ship from me such as the FJ R SPEC rods, Vitara pistons, Full gasket kits, YCP Pistons, Nippon pistons, Bisi intake gaskets...
Let me know what you need...
racist-bigot-sexist-homophob
FJT pls pm a shipped price for KMS intake and exhaust manifold studs for a b16.
Free shipping is not only to the continent of USA... more than one country out there..
Sorry only to the USA because shipping international is way more expensive..
a set of pistons that ships for 14-16 dollars to the USA cost like 39 dollars to ship International..
This special is ended...
Stay in touch for some more specials coming out soon.
1 - 17 of 17 Posts
