1 - 4 of 4 Posts
92 Accord Coupe
Im thinking about getting this Dohc ZC i found. Guy never took off the motor from when he had it shipped from japan. engine block says just ZC. its even got a ZC tranny, and axles but no ecu or harness.
What more common ecu can i use on this ZC?
And I was told this was about a 92 civic sir. true?
and if so, wouldnt the tranny be a hydro? bc im going to put it in my 92 cx but wondering if i need a new tranny first.
How much speed and accelation would i lose if i just bolted this ZC to my cx tranny? (which is new /w a new clutch)
95 Civic COUPE!
You will loose your whole power band if you put ure cx tranny... you should do do a zc si hybrid tranny they kick ass
Lifetime Awesome Member
'89 CRX HF
it should be hydro if its a 92. if it comes with axles, throw it in and run it. for what ecu, just use a chipped p06 or p28 and run a non vtec map with a little more fuel
1 - 4 of 4 Posts
