1 - 20 of 20 Posts
Honda City
L3 tranny. Rebuilt it recently, went well. Everything spins nice and smooth. Shifts into all gears too, with/without spinning the input shaft.
And then I saw this on my table:
I'm pretty sure it looks like the spring that goes under/over the tiny ball; though I don't remember leaving them out obviously.
Length of the spring is 22.x mm and OD is 5.x mm.
Put my out of my misery and tell me whether this is from the transmission or not.
And just to clarify, this is either from the shift arm shaft or the shift rod, right? Because I only remember ending up with 2 springs and balls when I opened up the tranny.
Love the Civic
Honda City
I didn't even take the shift forks apart. If the spring is from the shift fork and it has a ball too, then I guess I'm up shit creek because I haven't found a ball. Waiting for Bone to reply; I guess the tranny is coming apart anyways. FFS.
Love the Civic
Look at this thread rebuilding a z6 might not work the same for you, section 2 4th pic, might be what you feared. My last post was before I found more pics.
DIY: Transmission Rebuild (89pics!)
what if its a pen spring? wouldn't that just suck?
22.4-22.6mm, stiffy spring, is for the shift shaft rod that exits the back of the transmission.
under the bolt the socket is on in this pic....
Honda City
Just opened the tranny. The spring isn't from the shift arms, either of them. Bone, the one you suggested is a bit thicker than the one I've got in my hand here.
So I guess that just leaves the shift forks? Or could it have come from anywhere else within the tranny?
Edit: The shift fork that goes on the countershaft is moving without any resistance or clicking. Maybe I've found the culprit? I can see detents on the shaft but the fork won't click; it just moves freely.
Honda City
Now this is just fucked. All 3 forks have their balls and springs intact. So after a crash course in driving out spring pins and inserting shafts into holes while holding the balls down, I'm stuck with a spring that seems to have no home.
So this rules out both the shift arms and all the shift forks. Any bright ideas?
Love the Civic
The only one I can find that is near the measurement provided is in this pic. (Spring - L 21.4mm) middle of pic.
It is too the left of the one bone mentioned above.
if it is, I was totally being sarcastic
like this scene
Janitor: The door is broke. Maybe the fifth time or so. It don’t open.
J.D.: Maybe there’s a penny stuck in there?
Janitor: Why a penny?
J.D.: I don’t know.
Janitor: Did you stick a penny in there?
J.D.: No. I was, I was just making small talk.
Janitor: If I find a penny in there, I’m taking you down
As to why there are different spring lengths listed for the shift rod, I"ve never noticed a difference. I do have a parts tray FULL of the various springs that I have salvaged from taking forks and shift assemblies apart.
Used to be one online parts retailer that listed the spring length. The most confusing thing I even did though was having the spring cup (collar) fall out so there was very little side to side resistance.
Love the Civic
That's not an L3 tranny though. I measured the spring out of an L3 I had on the bench awaiting to be cleaned.
I keep doing that, searching for one, still come up with the hydro....sorry if I lead any one astray.
1 - 20 of 20 Posts
