1 - 9 of 9 Posts
2002 Toyota Tundra
I am building my D16Z6 to make roughly 300 to 350 hp. One of the things I am installing is supertech springs and retainers. Is it worth while to install forged valves with them if I am running the stock valve size? Do you think larger valves are needed to hit the 350 mark? This will be a street car on pump gas. What do you all think???
racist-bigot-sexist-homophob
No.
2000 Honda Civic EX
The stock head can make about 400hp but any upgrades you want to do will make your goal easier to reach.
See above...
On 98% of the D-series heads out there oversized valves are not an added benefit. Stock valves will tend to bend if contact is made, while forged will just break off. Other than some of the fordged ones coming with a nitrate coating, that's about all the advantages. I've not heard of anyone weighing the difference.
2002 Toyota Tundra
Hey Everyone,
Thank you for the info! I did not realize that the stock head could make up to 400 hp. It only makes sense as that appears to be the cut off for the block too. I was thinking about supertech springs and retainers, but maybe I should rethink that thought??? Should I pass on them and focus on other things?
90 civic si
Hey Everyone,
any head work will make your goal of 350 whp easier so id recommend upgrading the head parts just to make it easier
formerly Kit88
ek hatch
go for springs/retainers, this will help you to keep everything together revving high.
1 - 9 of 9 Posts
