1 - 6 of 6 Posts
Right, i'm thinking of buying this kit.
http://cgi.ebay.com/ebaymotors/D16-Civic-CRX-Si-Turbo-Engine-Kit-Pistons-Rods-Gasket_W0QQitemZ160203722017QQcmdZViewItem?hash=item160203722017
I'l rebore my engine to a 0.5mm oversize.
Do you think my bearings will be ok with standard size as in the auction?
Obviously i'l plastigauge it when i build it.
But i'm just wondering if i should get a different size. Or if its not "knocking" at the moment it will be ok. 142k mile engine.
Then i'm going to get ARP head stud's, should i get mains as well?
And is it worth getting better pistons?
Not looking to go crazy fast, it's just my daily driver. Whats the piston to bore clearance needed on the YCPs/vitara's.
Some of the question won't get definate answer's i'm just looking for a guideline and how other people got on.
http://cgi.ebay.com/ebaymotors/D16-Civic-CRX-Si-Turbo-Engine-Kit-Pistons-Rods-Gasket_W0QQitemZ160203722017QQcmdZViewItem?hash=item160203722017 if you look in the affiliates section, fjt has some kits that you could buy
Do you think my bearings will be ok with standard size as in the auction? the auction lists race bearings. which are thicker then "normal" ones.
But i'm just wondering if i should get a different size. Or if its not "knocking" at the moment it will be ok. 142k mile engine. if tear the engine down, you will have to replace the bearings.
Then i'm going to get ARP head stud's, should i get mains as well? d-series engines don't have mains available. you could get some made from arp.
And is it worth getting better pistons? the pistons are good
Not looking to go crazy fast, it's just my daily driver. Whats the piston to bore clearance needed on the YCPs/vitara's. go to: http://www.theoldone.com/articles/engine_tips/piston_data_sheet.html iirc, this is the specs i followed on my last build. either this one or the one on srp's web site. but they should still be very close to the same clearance.
i would look at fjt's site and what he has listed on here for a good deal on parts.
You might want to get the over bore 75.5mm vitara piston instead since you are boring your block. That ebay link is for the standard 75mm bore only. But like 99EJ6T stated, give FJT a pm'd or visit his site.
i would recommand oversized piston
i rebuild 5 d series motor for boost and for some odd reason every single one i rebuild needed to be bore and hone...do note these motors has 100k plus miles.
those bearing are fine i used them again check your clearance
arp head stud i would recommand
hope that helps
Sorry yes i was going to do this.
But obviously i as going to go for 75.5mm plus a clearance of 3 thou, not sure how much clearance and what ring gaps to use.
Thanks for that i will do this.
How much thicker are the race bearings i.e. how much will i have to get my crank machined.
I didn't mean leave the standard in there sorry for the confusion, i jsut meant standard sized.
Dam about the mains, what does everybody use then? Just normal studs from the dealer? I guess there ok anyway?
Awesome thanks for that piston to bore and ring gap info.
Is that for these pistons though? As they will expand at different rates surely?
Many thanks for all your help :) Is there anything else i should add to my list? I've got a timing belt, water pump etc already.
1 - 6 of 6 Posts
