1 - 16 of 16 Posts
what do i have to do ecu is a obd1 chipped p28
im selling car i just need to prove to new owner that the engine runs properly
in high cam
new info
i have a 95 gsr motor im parting it out my neighbor wants the head.I cant get vtec to accuate. he said he just wants to make sure the lmas and or rockers arent bad and this is the only way to do it. im in no way ripping someone off or being shady
Were not going to give you info on how to make something work, just so you can sell car to rip someone off! PM w/ explanation..
fixed thank you
gotboostedeg said:
fixed thank you
Im confused though, is motor out of car ?? If so Vtec is oil pressure activated, so I dont see how he is going to test Vtec engagment w/out it in car..
its installed all wires are installed except knock sensor, evap can sensor, and vss because the plug broke <--- this may be my problem i feel dumb
i installed it in my coupe just to show him it will run but i cant get it to go in high cam and now i look like a fool because he thinks the motor is bad when it ran fine last month
D
Im preety sure no knock sensor and vss could be the issue hook up those two then it should work
ok i have 3 wires and no plug which way do they go lol
hmm its running uberdata ill let you know tonight if it works
VTEC requires these things:
Correct coolant temp
Correct oil pressure
Sensors passing the resistance test in the ECU
and last, a speed check.
to see if its working, hook a led up to the solenoid to see if it engages.
PM me if u got any questions...
cool thank you for these replys
Discussion Starter #16
problem fixed ty
1 - 16 of 16 Posts
