if you have a 88-89 tranny get a clutch flywheel for that year(s)...and if you have a 90-91 tranny get a clutch , flywheel for that..the difference if how many spines each has i think the 88-89 has like 18...and 90-91 has 21 also the clutch is slightly bigger that 88-89 .... it makes no difference whether its 4 or 5 speed
actually the 89 90 91 has 21 spline the 88 was the odd one out with 20 spline , the flywheels however are different between 88-89 and 90-91 , the early model has a 200mm pcd for the pressure plate bolt and the later model has something like a 220?? mm pcd. But anyway to answer your question any d-series flywheel and clutch combo should fit just make sure your spline count is the same for the tranny and clutch plate
actually the 89 90 91 has 21 spline the 88 was the odd one out with 20 spline .. But anyway to answer your question any d-series flywheel and clutch combo should fit just make sure your spline count is the same for the tranny and clutch plate
