1 - 3 of 3 Posts
J
Can i swap a US D15B8 flywheel to a JDM D15b Vtec motor??? also are motor parts interchangable from one to the other...i.e timing belt....alternator belt....spark plugs....etc??
thanks for you help guys!
Jay
J
oh and how about distributor rotor cap??
thanks in advance!!
The closest cousin to the D15B is a D16Z6.
Distributor cap: 93 Del Sol Si... get Borg Warner... best construstion (same for rotor)
the flywheel should fit great. no prob there. Spark plugs and anything on the head is gonna be from a 93 Del Sol Si.
Timing belt will be a VX belt.... I think they started making those in 94 or 96.... just keep checkin till they find it.
plugs: stay with stock NGK's from the Del Sol Si.... best choice in my opinion.
make sure you use the Vx belt... everything else will not fit, or make a horrible whine like you got a supercharger installed...... not good to cam bearings.
1 - 3 of 3 Posts
