1 - 20 of 39 Posts
my 01 s10 has the same 2.2L motor that chevy has been puting in the s10 since the 80s. However my truck is equiped with flex-fuel and can run off of either gasoline, or E85(ethonal) made from corn. Wouldnt the d-series engine be able to run off e85 if tunned correctly?
88ED3 said:
whoa.....ask NASA, lol.
You fool.The older s10s arent flex fuel and cant run off enthonal but its the exact same engine as the newer ones. The only differenc is the computer and fuel injection. I think the flex fuel truck has a stronger fuel pump, and a fuel sensor. Maby e85 takes a little more fuel pressure . It take 1.4 gallons of e85 to make the same power as 1 gallon of gas but its only $1.00 a gallon and is made from corn. You know they are predicting running out of oil in 60 years. Alot of cars will be hybrid electronic or hydrogren/water powered in 40 years. I would rather convert my civic to run 80% ethonal or something. Its half the price of gasoline, renewable unlike oil, and has lower emmissions. I hope i didnt use to many big words.
wtf? read above
DontSaveHer said:
You fool.The older s10s arent flex fuel and cant run off enthonal but its the same engine as the newer ones. I think it takes a little more fuel pressure or something. It take 1.4gallons or e85 to make the same power as 1gallon of gas but its only $1.00 a gallon and is made from corn. You know they are predicting running out of oil in 60 years. Alot of cars will be hybrid electronic or hydrogren/water powered in 40 years. I would rather convert my civic to run 80% ethonal or something.
whoa, easy killer. i was jfwy man. i didnt mean it the way it came out. i see it now, and apologize.
wtf? read above
none the less, great concept and question. its beyond me.
Its cool, im a smart ass. UPDATE: E85, is a gasoline/ethanol blend that's 85 percent ethanol .
While it's theoretically possible to convert incompatible cars to run on E85, the EPA has made conversion illegal. I wonder how much Big Oil companys had to pay to make that happen?
This is clearly a case of the government talking out of both sides of its mouth. Auto manufacturers get credits for making a certain percentage of its vehicles E85 compatible(Chevy with 1.5million), but the end result of these incentives has been the production of ever-larger trucks. So if your name happens to be Ford or GMC or Chrysler, you can use E85 as a loophole. If you're a consumer looking to save a couple of bucks and/or support the farmer a few miles away and/or cut down on the amount of smog you produce during your commute to work, you can't use it.
Another nice thing about E85 is that it does a nice job of cleaning out your fuel system
Lifetime Awesome Member
'89 CRX HF
since the Honda you are talking about is forced induction...NO
E85 ethanol is 85 octane, you need 92 for your car to work correctly.
now if only "Big Oil Bush" was out of office so that this E85 could spread across the country so that we all could benefit from lower cost fuel, and cleaner emmisions...
there is the 15% Ethanol fuel available in the midwest though that is cheaper, and cleaner burning that comes in 92 octane though :TU:
Uhh correction on e85 being 85 octane. the 85 in e85 means 85% Ethanol. it is a higher than 85 octane. as for tuning. it requires a more rich air fuel ratio compared to gasoline. that is because the alcohol has the extra oh Molecule added to the carbon links
'89 CRX HF
oh, i know what the 85 in E85 means, lol. but i remember when i was in the midwest the ethanol blend being 85 octane, but it could be different with the E85
88 ED6
I just saw a BP commercial i think, whereas they advertised e85; they specifically said its 85% ethanol and is better for the environment. If it's going to make more power than regular gasoline or if i'm able to switch between the two(maybe have another ECU specifically for e85 and a seperate gas tank for it); than I will convert it. Fuck EPA; my car only gets safety inspection :p
88 CRX
:TU: That'd be sweet, i'd go for that, but i'm broke and I dont' wanna be the one to experiment with it, i don't have an expendable engine :|
hmm, well from wat i read/hear, alcohol in pure form is a higher octane then premium gas, so if using 87 regular gas how could it bring it below that?... but yes with minor mods the car can run it. becuase in the summer time i plan on converting to run almost pure. but i plan to put it on a dyno so itl run the correct AF for it. some people say it runs cooler, some say it runs hotter then gas, thats the part im not sure... maybe they think it runs hotter is cause it running lean then?
88 ED6
ethanol isnt alcohol ;)
I have two extra engines laying around(both D15B2s); I might just socket one of the ECUs and experiment with e85(if it's cheap of course; if its not, than thatll be awhile). I just need something to put the motor in though(go kart maybe? :D )
'89 CRX HF
wrong! http://www.infoplease.com/ce6/sci/A0858037.html
Properties
Ethanol is a monohydric primary alcohol. It melts at -117.3°C and boils at 78.5°C. It is miscible (i.e., mixes without separation) with water in all proportions and is separated from water only with difficulty; ethanol that is completely free of water is called absolute ethanol. Ethanol forms a constant-boiling mixture, or azeotrope, with water that contains 95% ethanol and 5% water and that boils at 78.15°C; since the boiling point of this binary azeotrope is below that of pure ethanol, absolute ethanol cannot be obtained by simple distillation. However, if benzene is added to 95% ethanol, a ternary azeotrope of benzene, ethanol, and water, with boiling point 64.9°C, can form; since the proportion of water to ethanol in this azeotrope is greater than that in 95% ethanol, the water can be removed from 95% ethanol by adding benzene and distilling off this azeotrope. Because small amounts of benzene may remain, absolute ethanol prepared by this process is poisonous.
Ethanol burns in air with a blue flame, forming carbon dioxide and water. It reacts with active metals to form the metal ethoxide and hydrogen, e.g., with sodium it forms sodium ethoxide. It reacts with certain acids to form esters, e.g., with acetic acid it forms ethyl acetate. It can be oxidized to form acetic acid and acetaldehyde. It can be dehydrated to form diethyl ether or, at higher temperatures, ethylene.
more info:
http://www.infoplease.com/ce6/sci/A0817769.html
http://www.uyseg.org/greener_industry/pages/ethanol/ethanol2Uses.htm
http://westernplainsenergy.biz/ethanol.html
http://www.chemguide.co.uk/organicprops/alcohols/uses.html
Discussion Starter #18
Ethonal needing a richer fuel mixture sounds correct. The flexfuled s10s have a stronger fuel pump, and a sensor to detect the ethonal in the fuel system and change the FuelInjection setings to get the correct air/fuel ratio. It takes 1.4 gallons of e85 to produce the same power as 1 gallon of gas so it must take more fuel pressure or keeping the injectors open longer to get the correct airfuel ratio. Its doesnt get as many miles to the gallon but its 1 dallor instead of 2 a gallon so you still get more miles out of your money.
EG Final Year
I wish my chem class was like this I'd prob pay more attention. And yeah anything with hydrocarbon compound with ol at the end has a hydrogen bond and a form of alcohol. Ethanol CH3-CH2-OH.... I'm gonna see if I can get any info about the ethanol needing a higher fuel pressure and maintaining A/F ratios.
build a dune buggy!
1 - 20 of 39 Posts
