1 - 4 of 4 Posts
I recently bought a 97 civic dx, the guy gave me a y8 head, a z6 intake manifold and the ecu from a 98 civic ex. I was hoping I could get a tutorial on how to wire it and if this would even work together. I know next to nothing about cars, and I would like to start getting to know them better. So what would I need to buy like wires and hose and stuff along those lines? and how would I wire it?
Do a quick search y8 mani swap or mini me. I dont think any one is going to post a write up for you.
:popcorn:
Like all other forums they have rules you should read first.
y8 head swap
i did the same swap on my 98 dx runs great. all i did was buy a 96-00 ex wiring harness on ebay and plug it in (simple) and i think i used a p28 ecu. the only wiring you have to do is a 4 wire secondary o2 sensor under the car. if you want the easy way i went to the junkyard and took the 4 wires for the o2 sensor out of an ex civic just leave the wires in the plugs so you no where the pins go in your car they will be empty so just push the pins in. good luck
1 - 4 of 4 Posts
