1 - 3 of 3 Posts
I finally got my wideband put in and did some datalogging. Here's some screenshots. I'm assuming the spikes on the graph should not be there. Any suggestions would be appreciated.
Also there isnt anything being logged for hi cam
my vtec is also off and Im not sure where to fix this at
d16z6 w/ intake and exhaust
Crome dealer
Innovate lc-2
Love the Civic
Do you have the manual?
http://www.ej9.ru/data/book/crome-v1.6.x-manual-pro-dealer.pdf
The second graph isn't readable, too small.
You can use the number graph with the line(?) graph. Remember the chart is on its side compared to the first(line) graph. You can use it to determine why it spikes early instead of running up smooth. Should have numbers that do not coincide with the next in the row or column, I cant remember exactly. New to it myself.
Yep I have that manual. Thats what I've been going off of as well as a write up on here. I made some corrections so Ill do some more logging and see what changes
1 - 3 of 3 Posts
