1 - 20 of 35 Posts
Just got my block and crank back from the machine shop and have a few question.
1. I will be using the a6 oil pan and pick up. The a6 spun a bearing and had flakes in the pick up tube. Is there a trick to get them out of there or buy a new one? Also should I worry about flakes stuck in the baffle of the pan?
2. Is there a certain orientation for the piston rings during install?
3. Dipstick? Stick with the a6?
4. How do you do initial break in on a rebuild zc. I've done Honda motors before but I'm a little scared since I'm reusing a few parts that were in a motor that had spun bearings.
Thanks guys I can't wait to finally have this done
Well as far as ring order I believe it is:
1.First Ring
2.Second Ring
3.Then 1 Oil control ring
4.Oil Ring expander
5.1Oil control ring
Then an important thing to keep in mind is that you need to spread the rings in the gaps in a certain order around the piston (I think), you dont want any gaps touching each other, Heres a picture I pulled off of google. I honestly don't know about the a6 dip stick though, I guess i would start off comparing them side by side and checking features. I may be wrong, but with break in I don't think there is anything special, Lower rpms and just alow every part to get worked in, rule of thumb I would say 500 miles is plenty for break in.
Thanks thats the picture I was looking for. Couldn't find it again. I should have been more clear, I was asking about piston ring gaps.
08 H-D Ultra Classic
:bowdown: Need pix of the wagon asap !!!! :fingersx:
:hyper: :)
Thanks I got all that done. Going to put the pistons in tonight. My ring compressor broke because it was old so I need to get a new one.
Any advice on the oil pick up? Probably will just get a new one buts its $100 the cheapest I can find
1998 Hatchback
if you ask me buy a new one
It's a discontinued oem part which sucks. Sealed power makes one for about $130. I found a Honda dealership called sons Honda and ordered it online there. They said they had one in stock I'm hoping it is the correct one because it was only $55
\/Your Mom Was Here\/
Vibe GT
Use an a6 pan and pickup. Look on the for sale forum in here and I'm sure someone is selling a pan and pickup.
EDIT: You can use b2/b7 pan as well but get the pickup tube to match it
Tape-R taper/driver
EC3, ED8, ED9, EE5
RT4WD and non-RT4WD pans don't mix. The oil pan gets into the kick-out for the rear drive-shaft.
Ask me how I know.
Also, only blocks with the holes for the jack-shaft can be used:
That leaves you with A6, Z6, and ZC.
1988 Honda CRX Si
This looks sexy!! I'm currently talking to someone that has a ZC DOHC without the cams. Not what I really want, but figured why not pick it up, if its all clean looking and comes withe everything else intact for a good price.
1 - 20 of 35 Posts
