1 - 6 of 6 Posts
formerly Kit88
I´ll start tomorrow my rebuild on my a6 block and z6 head, you must remember that I blow my last engine.
The block is in great conditions and includes the main cap, is on standard bore, new oil pump, new water pump, I´m gonna use same vitara pistons and 1 new eagle rod, acl bearings and hasting rings.
I´m gonna check all the clearences with plastigauge, also I´ll check ring gap, and ptw clearence (between .004-.006)
d16y8 head gasket, but I´m not shure if the timing belt tensioner on the a6 is the same on z6, does any one have idea about this???
I´m gonna use the z6 timing belt.
Please help me to check if I´m missing something.
Hopefully I´ll be on the 300-350 whp with my 50 trim at 18 psi, tuned with eCtune.
Also I have 3 bar map sensor and boost solenoid.
formerly Kit88
formerly Kit88
Thanks
1 - 6 of 6 Posts
